- Joined
- 1 Sep 2015
- Messages
- 368
- Reaction score
- 5
- Country
We're in the stages of renovation, and we need to desperately sort our shower situation. We've had a new boiler recently, so please don't suggest a combi Also, is isn't possible at the moment to replace the cylinder with an unvented. We had enough joint leaks with the heating being pressurized and the rest of the house has been freshly decorated.
Currently running a pressurised heating system, and an vented hot water system with 2 shower pumps to power the ensuite and main bathroom showers.
Unfortunately this looks like a particular bad DIY job. The plumbing is somewhat of a mess, and the shower pumps are in a word, noisy. Nothing seems to be fixed down, and they're positioned on a hollow floor so you can hear them throughout the house. The airing cupboard is also next to the master bedroom, and since there are varying morning start times, we need this sorted otherwise some people will be getting an early wake up call from the noise!
I'm also sure one of the pumps for the main bathroom has had it. The water simply dribbles out like there is no pressure.
You might also notice that there are 15mm pipes running to the showers. Not sure if this is right, as the connectors on the pumps are 22m
Current plumbing mess:
Existing Pumps:
Now plumbing isn't our problem, nor is joinery or anything else, I'm really just asking for some recommendations.
What shower pump, or shower pumps can I get to resolve both the pressure issue in the main bathroom, and also the noise?
I plan on creating a soundproof box to put the pumps in, and fixing this to the floor properly to stop it from rattling the house to the ground
Existing Pumps:
