I have a Texecom Premier Elite 24 which is currently running firmware version V5.01.03 LS1.
It is connected to a SmartCom which was running v03 firmware.
I have just used the Texecom Cloud Services (cloud.texe.com) to upgrade the SmartCom to v04.04.00.
I would now like to proceed with an upgrade to the panel firmware.
When I select 'Upgrade Firmware' on the Texecom Cloud Services website, I can choose from:
* p24_v6_05_02_LS1_OTA.bin (v6.05.02)
* p24_v6_03_02_LS1_OTA.bin (v6.03.02)
* p24_v6_02_02_LS1_OTA.bin (v6.02.02)
* p24_v6_01_11_LS1_OTA.bin (v6.01.11)
* Elite 24 V5.06.00 LS1 (V5.06.00)
When I select the v6.05.02 version, I am presented with the following message:
My questions:
1. Is there any reason NOT to upgrade to the latest version (v6.05.02) or things that I should consider as part of this upgrade?
2. Could someone please provide me with any guidance on how to put monitoring 'on test' and how to disable the sounders as the message above advises?
Thank you.
You have selected to upgrade the firmware on the Premier Elite panel which requires confirmation from the site.
Outputs relating to signalling and connected safety devices may activate during the upgrade. Please consider the implications of this: ie:
1. Ensure monitoring is 'on test'
2. Safety devices/sounders are disabled or disconnected on site.
Please note: Firmware upgrade should only be completed with the SmartCom connected via the Texecom supplied 60 cm cable.
Are you sure you wish to continue?
My questions:
Thank you.
