Screwi said:no you cant use that batt - you will damage the electronics as they wont be rated for the increased charge current and longer time plus more heat etc etc
plugwash said:using a seperate charger could do more harm than good unless you are very carefull.
the trouble is you don't really wan't to connect two chargers together so you will have to design some switchover system.
also if you plan to keep the original battery as well you have the potential issue of current flowing between the batteries when they connect together and if you don't then you are likely to get a brownout as your switching system activates.
FWL_Engineer said:Andrew, the charger you have will charge the battery, or both of them if connected in parallel. It is the voltage that is important, so long as this is the same then your OK.
Of course the charge rate will be dramatically reduced as a result and the time taken to charge both batteries from empty to full will depend purely on the charge rate of the charging system.
I wonder why you need a 50Ah battery in conjunction with the existing 7Ah unit? Domestic UPS's are not designed to run the machines, they are designed to allow controlled shutdown after you have saved your work, in essence. The software that came with your UPS may not allow you to run a machine longer than a set time due to heat stresses and electrical stresses in the Inverter it contains, I would be more concerned about this than whether it can charge the batteries.
thanx. ive ordered a seperate charger for itbreezer said:i do not think it wise to use a 50 ah batt on a charger that was designed for only 7ah batt.
yes in theory it will work, take longer to charge etc, in practice it doesn't always work.
as batteries are getting flat, bigger one may discharge into smaller one also when 50 ah batt is flat it will draw a heck of a lot of current at initial mains restoration, this my be too much for your charger, also if it is being trickle charged all the time, the battery may never recover if it goes flat.
