We have a pretty old bath with mixer taps and shower hose.
Shower non powered, gravity driven from tank in the loft
Cold water no longer comes out of the shower head when attached to the wall
Experimenting found that it worked if the shower head was level or below tap level. Hmmmm!
The hot water tap pours water out at quite a pressure.
The cold water tap very much less pressure, frankly pretty feeble.
Had a look in the tank in the loft and nothing appears to be amiss. Clear water and nothing blocking the out pipe
Now also realised that the loo in the bathroom also takes a while to fill up. Hmmmm!
Before I call a plumber out is there anything I should try / look at?
Many thanks
Many thanks
