Hi, I have a Saracen multi point door lock for the garden, with “032” mark on it. It has 2 hooks, 1 deadbolt, and 2 roller cams.
When I turn the doorhandle up (with the door ajar), the hook and roller cam at the bottom comes out a little, deadbolt in the middle comes out about 5mm, and the hook and roller cam at the top come out a little too (but not a much as the ones at the bottom) but not fully. Also, I can see that the middle section of the lock, near the deadbolt has bulged out a little, and when I try to force the lever upwards, I can feel it is catching somewhere in the middle and making the middle section bulge out by about 2-3mm. In fact, one of the screws in the middle has come loose and when I try to screw it back it just turns freely.
It previously used to work OK (although it would always require a lot of force upwards to get it to engage.
Is there an easy way I can fix this, or do I have to get a DG/locksmith out?
