Hi
I'm having two new en suites tiled in a loft conversion that has just been made.
The builders are doing the tiling (I know, I know, never let builders do tiling...)
The tiles are Porcelanosa wall tiles 1000mm x 330mm ceramic.
They are being laid on plywood. The adhesive is 'one flex' as supplied by Porcelanosa as is the bonding agent.
The builder didn't read the instructions on the adhesive properly and rather than using the technique as described on the packet as 'float and butter' he just put huge blobs of adhesive on the tile and pressed them on.
Now they are all up straight but they haven't stuck properly and are loose!
Porcelanosa obviously say that we haven't used the technique as recommended by them.
Not only that but when the builder discovered this in one en suite this morning he ordered his own preferred adhesive and started using that in the the second bathroom (using the same massive blobs technique)
Now in the second bathroom they do seem to have stuck on solidly. So my questions are
1) What is a butter and float technique?
2) The first en suite will need all the tiles stripped off, but shall I let him finish the second en suite since they do seem to have stuck on properly. Or will I have problems later on?
I'm pretty sure I'm going to ask him to abandon the tiling and get a professional tiler in to do it. But shall I let him finish the walls in this second bathroom?
3) On a side note, I was going to put 12mm ply on the floor (just joists at the moment) and tile on top of that. Is that ok?
Thanks for your help.
PS, to be fair to the builder he has done a good job on everything else, perhaps he should have left the tiling to somebody else!
