Hello
I have a typical 2-way lighting setup where 2 switches control the same light. The light itself is in my lounge with one switch in the lounge and the other next door in the kitchen. The switches are 2-way with a common terminal.
I understand you cannot easily replace both switches with a dimmer, it's more straightforward to just replace the lounge switch with a 2-way dimmer and leave the kitchen switch unaltered, is this correct please?
In which case how would this operate in practice?
For example, lets assume the dimmer is set to a low light level. Would the switch in the kitchen then either turn the light off, or on at the level set by the dimmer?
If the dimmer is set to full brightness or off altogether, would the kitchen switch then switch the light off or on full?
Thanks for your advice
