Using Multiples Taps same time
15 Jun 2007
Glasgow
I have this big problem and I am wondering if anyone knows how to solve it.
I have 3 sinks both with cold/warm taps in separate room. They are all working fine however 3 of these CANNOT be used at the same time??? If you use 1 the other fails to give hot water but it gives cold and so on.
Is there anyway you can run 3/4 taps same time all hot water same good pressure?
So annoying you have to wait till one person stops using a sink before you use yours sometimes a 10-15 min wait!
Yes, just have a new 25mm mains water supply connect to an unvented cylinder and bobs your uncle.
which will work a treat gasman IF the water boards supply provides the pressure/flow
darrn my way a lot of areas it doesnt
Thats what you get for living in such an affluent area.:wink:
Although I do have one customer with no water or mains supply, waiting for a borehole to be drilled out.
Plumbcenter...£1495.45 plus fitting.
No, if you know what you are doing and you have an unvented ticket.
Is it perhaps the poster has a combi boiler?
Fitting UV is the way forward as suggested. But must be done by the book. In process of fitting three this month (different clients of course)
if they were all in the same house WOW
gas4you said:
What is :?
A pair of my jeans ;)
lmao
Dont forget OP it may not be as easy as whacking in an unvented job done
your rising main must be a minimum of 22mm and as gasman says you will need to upgrade your water main (probably) and as I said this will only work IF the mains supply is adequate
if the water supply is not good enough for a combi it sure as eggs aint good enough for a unvented
Considering the OP has'nt devulged any information what so ever about what system or supplies they have, I can recommend anything.
true
then I willl recommend that the punter re routes the river thames through his bathroom and utilizes a small nuclear reactor to provide the heat
job done
and I would love to see some notify CORGI about that
