Hi All,
I have an issue which my plumber has been struggling to get to the bottom of so thought I'd post here for some ideas!
I have a 300l UVC which loses all its heat overnight. It's been like this since day one. The house is a self build.
Initially we thought it was because there wasn't a NRV between the pump and tank (you could feel the pipework become cold to touch when the pump wasn't running). The NRV solved the cold pipework at the pump but not the loss of heat in the tank.
The secondary return pump works on motion now (we thought maybe we were losing the tank due to it running 24/7). Now if motion is detected in the house the pump switches on and if no motion is detected it switches off. This means at night it's not running. We continued to lose a full tank each night.
In any case I have been experimenting over the last few and as I said before if the pump is switched off but the secondary return not isolated then I still lose the whole tank in one evening. If I isolate the secondary return pipework the tank stays hot overnight.
So the issue is something to do with the secondary return. There are two theories. The first is that the secondary return has maybe been mixed with a cold mains at some point in the house. However if this is the case when I isolate the hot water at the tank and isolate the secondary return shouldn't I get cold through the taps? That's not the case. The second is maybe one of the mixers is faulty and letting cold back up hot (but then wouldn't this be a problem even with the secondary return isolated?).
Any thoughts on this? The plumber who did the initial install is AWOL so I can't even check with him to make sure he tested the pipework / to ensure nothing was crossed!
