hi all,
Have a hot water issue with my Vaillant ecoMAX 824/2 e. (edit, model number updated, originally incorrectly called it an ecotec).
Heating works fine, however when you run the hot water you’ll get a short burst of the correct temperature before it going Luke warm.
Basically turn the showe on, and you can see the temp reading go from a low (say 30degrees) up to about 75oc, before the main burner seems to cut out and the temperture just drops, and drops, until it reaches around 50degrees (not that it feels close to that warm out the shower). It doesn’t seem to attempt to ever re-engage the main burner. Shows “S.14” during this process by the way.
I’ve replaced both hot water NTC’s with genuine parts to no resolution thinking this could be the cause. Anyone have any ideas? Thankfully whilst chilly, I can just about withstand a shower as it’s not stone cold, but obviously want this sorted pretty sharpish!
Thanks in advance!
Thanks in advance!
