I'm replacing my boiler and I wanted some advice.
Basically, i'm going for one of the above boilers - i know the 837 is bigger in size and power, and that's not an issue.
The issue is that it's £140 more, and potentially another £350+ if the pipes need to be rerun and resized to fit it.
I also may need the pipes for the 831, but there is less of a chance...
2 of us live in a 3 bed victorian semi, 2 bathrooms and a loft conversion. I'd like to be able to run both showers at the same time, as the flow rate is acceptable...
Can anyone advise if the 831 would be fit for this purpose, or should i sump for the 837...
