Vaillant Boiler Eco Tec Leaking
8 Oct 2019
Hi. I have a Vaillant Eco Tec Boiler we have just moved into the house and it looks like it was installed in 2007 - we’ve just had it serviced about 2 months ago and it’s now leaking and needing topped up every other day.
Nothing on the radiators but the discharge pipe under the boiler I attached a bag to that last night and this morning had water in it. How do we fix?
Call someone in - the expansion vessel is probably flat (in which case it wasn't serviced properly) or failed (in which case it might have been serviced properly and this happened afterwards). Either way, it's behind the room sealing cover of the boiler, which should only be removed and refitted by someone who is capable of carrying out the regulation 26.9 checks on completion, IE a Gas Safe Registered Engineer
