vaillant boiler query
26 May 2011
Gwent
hi, i have a vaillant ecotec pro and it looks like i need a new pcb. just a couple of things i need to know.
how can i tell which model it is so i order the correct pcb,
and are they difficult to change?
and how much should i look to be paying for one?
had no heat or hot water for nearly 3 weeks now and my wife is going to leave me!!!
pcb expensive you can only tell with multi meter
and easy to change and the gc below the boiler you would need this
but i would consider get in rgi to check it out first
p.s. why do you think its the board
just read your previous post
have you got power to the board if so have you got power to the pump
there is power to the board, not sure about the pump. how can i check?
same way you checked the power to the board
follow the cable from the pump to the board and theirs your lne
why do you think its the pcb? they're pretty reliable on these boilers unless the diverter valve has leaked in which case that'll need changing as well.
Faulty pcb is often the conclusion from people that are not good at faultfinding when it is actually something else.
What makes you think it is the pcb?
there is power going to the board and pump but the boiler is dead, no lights or fault codes. this happened after a drop in pressure due to a leak on the pressure sensor . pressure is back up but boiler is dead. all fuses ok.
right i would recommend you get some one in as it may not be the board but at same time it may be ring vaillant see how much they charge and ring bg for fpf on the boiler and the aa and local and see what price will be
someone came today and fitted a new sensor. its working for now but needs a new vessel. he said my best option was for an external one?
got to ring him later and speak to him about it
yeah he pumped it up but its leaking. said it would probably last the summer but not when the heating strats being used constantly. going to get the external one fitted when i can
