Hi all First post,
I have lurked around a bit when choosing boilers etc a while back and see a lot of good advice given.
Having a bit of trouble with combi boiler, Vaillant Ecotec 837
Boiler was fitted about 3 years ago and have had no problems since then. but in last week started to get a high pitched whine/howl from the boiler that was carrying into the upstairs bedrooms. This tended to appear only when the house was getting up to temperature after being off overnight or when we we have been out during the day on max and the burner hit the max setting, staying there for a fair period.
I have a homecare agreement with BG and they sent an engineer out to have a look. He checked it over could not see anything and put in some boiler silencer. My wife was in when he looked at it so do not know what he actually checked. Got back at night and turned on water to fill bath and the boiler starts making a racket. There had been no noise with the DHW before only when heating.
BG called back out again and looked at it again. Different engineer, looked at it for a while before deciding we needed a new heat exchanger and telling me probably need a power flush. Didn't have the part so back next day to fit it, I was in this time, he spent ages at it it deciding it wasn't heat exchanger, thought maybe combustion problem ( said pressure was lower than recommended for boiler 16mb I think) before deciding on fan making the noise so he did not change part. I meant to say this only happen when drawing from bath or shower not from whb taps/sink. He showed me when the fan speed increased to higher levels then the vibration starts.
Back next day with fan, wasn't around again as had to work, my Dad was there this time and Eng tells him he has fixed it. Get back tonight, boiler seemed quieter not as good as before but pipe is hissing at cold water feed, the valve was only partially opened which seemed a bit strange.
Opened this up a bit and the noise in boiler returns, don't know if he replaced fan, I must presume so.
Question is should he be restricting water flow to the boiler, doesn't seem to be fixed as far as I can see.
Just want to check more knowledgeable people thoughts before going back to them tomorrow, I feel they are likely to give me the run around.
Any comments appreciated
PS He had also changed his mind about the power flush saying the water quality wasn't as bad as he thought the other day
Ian
Ian
