To the bunnyman and bell : If you're trying to help somebody, maybe you should sound helpful rather than condescending and scornful.
To The831Bunny, thanks for the info, appreciated.
So updated MIs aside, what is the drop on a correctly sized gas pipe from meter to appliance? I think you'll find it's 1mb.
Gas supplied at the meter 21mb ± 2. So just because you've got your 15 mb doesn't mean there's not a problem on the gas installation, ie meter governor, as I previously posted. And if ALL appliances don't have their manufacturers minimum working pressure with them all running at full rate, and they don't gas rate correctly, then combustion is affected and it's AR for the appliances that don't gas rate correctly.
Which is what my original post was about - the BG engineer recorded 16mb, and left.
So you'd walk away on a 15mb inlet pressure because Vaillant say their boiler is ok at that? With a possibly failing meter governor?
I read my regs, I have to, I'm self employed.
@ bell824, I did read the MIs from Vaillant's website. And it's YOU who needs to read his GIUSPs.
