Hi all,
Hopefully, you may be able to help. We've got the above-named boiler (it's an 800 series, 824 iirc) and it's behaving a little strangely.
The central heating system works well (considering the radiators/pipework have been installed poorly (this is slowly being corrected as and when time allows)) and there are no significant issues with this side of things - there is a small leak on some pipework which equates to the heating system requiring topping up every week or so, I appreciate this will contribute to the overall problem, especially as we have hard water where we live. I'll be replacing the plastic pipe section with copper in the next few days all being well (thank goodness for some holiday time).
There is, however, an issue with the DHW side of things.
Opening the hot water tap fully, we get very hot water for a short amount of time (maybe a couple of litres) and then water cools to a luke-warm temperature. The tap symbol doesn't appear on the boiler display but the boiler fires.
Pressing the 'i' button when drawing hot water, has shown status messages of S.24, S.28 & S.30.
Closing the hot water tap, the system appears to continue running/firing and has, inconsistently displayed a water temperature of 84°C, when opening the hot water tap, I can believe water temp is about that as it's steaming hot.
If I open the hot tap approximately halfway, water temp remains quite warm and usable.
Lastly, I understand that I can't (or want to) touch the gas side of things, but I'd like to try and understand why the boiler is misbehaving. We've limited experience of trades in our area and have been burned by a cowboy outfit once already (a roofing firm).
Any help or guidance would be very much appreciated.
Regards, J.
Regards, J.
