Vaillant ecotec pro 28 F75 fault
9 Aug 2019
A brand-new pressure sensor was fitted not long ago following an F75 fault.
However, the digital display is currently showing 1.9 bar, which does not correspond with the reading on the boiler’s physical pressure gauge.
I've reset the boiler, but as soon as I turn on the hot water, it immediately goes back into an F75 fault.
The engineer who attended today is insisting that the pressure sensor is faulty again and is recommending replacing it for a second time, despite the previous one being a brand-new genuine part.
I'm reluctant to keep throwing money at the boiler by replacing parts without getting to the root of the problem.
I'd really appreciate a second opinion on what else could be causing this fault before agreeing to another sensor replacement.
Depends how dirty the system is, but F75 can be 1 or several or a combination of faults. Does the pump kick in when you reset? (Should be able to hear it after the diverter has moved)
Depends how dirty the system is, but F75 can be 1 or several or a combination of faults. Does the pump kick in when you reset? (Should be able to heat it after the diverter has moved)
Previously it would go into F75 fault after a few attempts at starting, now it immediately goes into F75 fault
Could be the pump. Can you hear it when you reset?
Not sure my hearing isn't great :(
What's the likelihood of the sensor being faulty again? I'm not sure if the engineer cleaned the area where the sensor goes into, but did say the sensor was dirty.
Could it be that he didn't clean the area where the sensor goes into?
On the first visit the engineer also said the expansion vessel was flat he said it wasn't leaking from the valve, but added air to it.
Could it be the expansion vessel if it's flat again? How often does the air need to be added?
Hard to say really, as I said, depends how dirty the system is
Aye, could be, but not always necessary, I always try and check if it has debris inside where’s the sensor sits
Could be, not impossible, but unlikely
Could it be the wiring loom to the sensor?
Shall I just authorise him to replace the pump and sensor for peace of mind, can't afford to be without hot water and heating at this time of year.
I don’t think I’ve ever had f75 for the loom, usually f73 or f23 (iirc)
No, it should be one or the other really. Unusual and unlucky to be the 2, although I have had it. It could also be the pcb - had this once and it caught me out as I thought it was the pump! The pcb failed to deliver the voltage to the pump.
Find out how much his charge will be and seek a quote for Vaillant fixed price repair, see which is cheaper
If voltage is being delivered to the pump, then it'll be the pump at fault?
He's coming tomorrow, will report back on the outcome, many thanks
If it can be stopped easily. Other thing it can be on the pump is the capacitor, which can be measured using a multimeter with capacitance measurements
Engineer called, he's now told me it could be the wiring loom to the sensor, he mentioned the contacts/pins looked corroded he cleaned them as best as he could.
Not sure what to do, any thoughts?
He thinks it's unlikely to be the sensor, despite their being a difference in pressure on the digital gauge Vs the analogue gauge inside the boiler. But suspects this to be due to the wiring being faulty!?
It could be. He will likely know better than me, as he has seen inside
Unless you can provide a photo, unfortunately not. Or go Vaillant fixed price repair
A manual gauge doesn’t tell you much. The pressure sensor is the one that determines whether the boiler is going to work without fault
I'll have to wait and see i guess, last thing I want is parts being thrown at it, rather get the boiler replaced for total peace of mind!
