5 attempts is normal for gas boilers before they lock out so irrespective of whether the fault is associated with the pressure sensor/wiring or whatever (unlikely IMO) then the pump should at least have started which the engineer should clearly have heard (if it did) when he had the boiler casing removed, I'm not familiar with gas boilers but I would be very surprised if you couldn't hear it standing at the boiler.
The only gas boiler I'm a bit familiar with is my daughter's Vokera Vision 20S, if you power this off completely and then restore the power, it (even in a healthy state) will do a air purge, the pump starts and stops 4 times and then the boiler will fire up, I can very clearly hear this pump starting each time. Don't know what your boiler does but it might be worth powering it down and back up and listen. So, IMO, it should be first established if the pump starts up, the engineer should know all this.
As suggested above, a Vaillant fixed price might be the best option.
