I have a 9 year old Vaillant TURBOmax Plus which developed a problem a couple of years ago. When the central heating is on sometimes the radiators go cold. When I go to the boiler it is still churning away as though it is working (fan/pump going) but the heating indicator light has gone out. This is resolved by switching the boiler off and back on again. It doesn't happen very often and doesn't happen at all in summer when I use the boiler only for hot water.
When it first happened I rang Vaillant to try and find out what would cause it but they didn't seem very sure of themselves and were more interested in getting someone out at a cost of over £200. They did say it seemed like the diverter valve. I got a local plumber out who said it wasn't the diverter valve but was.... embarrassingly I can't remember but it was a three letter abbreviation and there are 2 of them in the boiler. He changed one and it had the same issue. He swapped it over the the other one and it seemed to be okay but the issue eventually returned. Because the problem is intermittent I don't actually know if he actually fixed it or if it took a long time to show itself again. The problem seems to be heightened when all the radiators are on (i.e. under more pressure).
My sister has been given the same boiler by a plumber for spares (one he took out of a house) so I have access to most bits. Does anyone know what is likely to be causing this issue? What is the three letter abbreviation that the plumber replaced?
Thanks in advance!
EDIT : Looking at the manual - when the fault occurs the Yellow indicator goes out (so the main burner is not ignited) but the boiler itself is still pumping so presumably 'knows' it needs to be producing heat.
Thanks in advance!
