I posted this a couple of days ago and it did fix the problem for 24 hours. The post can be found here: //www.diynot.com/forums/viewtopic.php?p=1629768#1629768
I have a Vaillant urbomax Plus 824E Combination Boiler. It was showing 0 pressure but now is staying at 1 bar (in the green and good). We were getting constant hot water for 24 hours and now, it is cold. I will mentioned that this morning when I took a shower, it was nice and hot and I never noticed a drop in temperature (even on the boiler). And every time we noticed this issue, it always seems to be at night.
I checked that the boiler is suppose to always be running (on the middle dial with the burst symbol). I am not getting any error codes and check everything that I possible can think of. Water will come out when we turn the hot dial, but it will be cold.
The only thing I can see that sounds weird is that when I turn the boiler off for a minute and turn it back on, hoping that it will fix, I can hear it running and then after a minute, stop. The green light is still on, and the smaller green light is blinking. Does anyone know what I can do to fix it?
Thank you in advance for any advice you can give.
Kindest Regards
Andrew
Pictures of the boiler is shown below:
Kindest Regards
Andrew
