hello all
new to the forum and ? anyone can point me in the right direction
I'm wondering if this is the PCB that is on its way out , the boiler is about 19 yrs old so i can't complain
the flame indicator light stays on after you have either hot water or the heating on , this appears to then lock out either function coming back on again when you call for heat, although the fan will come on.
switching off the power for a short time doesn't help, but if the power is off for longer ie 1hr+ then all works again fine.
it is intermittent problem at present but does seem to be becoming more frequent
cheers ian
cheers ian
