I have a vaillant turbomax plus 828e combi and need a manual for it since the previous owners of the property didn't leave me one..
I also have a few problems with the CH and hot water that need fixing ( hence the need for a manual.. )
there is no hot water coming from the boiler since I turned the CH back on for the winter, it was working fine until then.. ( I'm assuming that it's a valve gone somewhere in the boiler.. )
I also have a leaky ball valve on a radiator pipe that needs replacing or removing..
It was there when I moved in and the reason for it is not immediately obvious to me.. it's under the radiator, about 8 inches from the TRV...
surely the valve on the other side of the rad is for balancing the flow ( it IS the last one on the circuit, and furthest from the boiler.. )
anyway, it sprung a leak some time ago from where the screw head is..
it drips but I thought I'd cured it last year..
when turned to a specific point, it stops leaking ( in the open position but slightly up from fully open, and only in one direction.. ) so I'm assuming it's worn or warped for some reason..
it started dripping again friday night for no good reason and no amount of fine tuning with a screwdriver will stop it.. so it either needs to come out or be replaced like for like.. ( I vote the first to prevent a repeat performance.. )
if there's another suggestion to stop the leaking valve then lets have it by all means..
I've thought about trying to drip superglue onto it to "seal" the gap round the screw..
anyway, it's replacement ( and possible replacement of the divertor valve / heat exchanger / whatever is needed to fix the hot water ) will require the draining of the rads and subsequent refilling ( or topping up since the pipes all go upwards and would only drain the legs the boiler ad rad is on. ).
it's this that I need the manual for, I've no ldea how to do it..
