hi all, last week i changed the DHW heat exchanger on a vaillant GB 242 EH its about the 3rd ive done in the last few years, the others with no problems, this 1 however....
after refilling an checking there was no leaks i thought the worst was over, i then turned the boiler on, the pump ran the fan ran but no ignition. In the end i had a word with 1 of lads in the merchants i use an he told me that you can have lots of problems with air wen refilling, by this point the pump was also on its last legs (which i thought might not be satisfying the pump proving switch) so i swaped that made sure all air was nicely purged and then all worked well.... until today i recieved a call saying the heating isn't working. Ive been back and looked tonight and the diverter although may b a little slow appears to move an switch micro switches as it shud, but the heating is intermittent to fire an only holding in for short periods of time sometimes and other times holds in till it goes off on stat. the hot water works fine still. could it be anything to do with the servo valve i've read about on previous posts? 1 of the connections on this looked a little coroded, but i cant remember which 1 it was or where the pipes came from at the mo
its the none hybrid board and i changed the diverter disc when i did the heat exchanger (which was changed due to leaking)
any advice would be much appreciated
thanks gaz
thanks gaz
