You need to put a bag or condom over the vent pipe to see if its pumping over.
Depth cold in F&E tank?
Distance between vent pipe and water cold?
Tony
will leave it off overnight and check in the morning...
Tony
Tony
depth of water in tank when cold 6"
distance between tip of vent pipe and water surface in the tank er its in the water by 1". The vent is a 22mm arm created in such a way that its actually sagging. When uprighted, the tip of the pipe is 2" above water. Its been in the water for some time as its corroded.
Because its under the water it forms a loop which has a low flow resistance and can easily cause circulation
