    Dismiss Notice
Valiant Ecotec 824e Firing Up When Not Needed
Discussion in 'Plumbing and Central Heating' started by iamlee2002, 10 Jan 2011.
  1. iamlee2002
    iamlee2002
    24 Nov 2009
    209
    Thanks Received:
    5
    West Glamorgan
    Country:
    Hi all, ive recently modernised the bathroom not finished yet though. I have noticed something unusual, If i flush the toilet or run the cold tap (opened fully so fast flow) when the water stops flowing (tap closed) the boiler fires up then i get a "pump over run" status code.
    Any ideas? i havent crossed the piping, however i have put 2 isolating valvles near the boiler.
    One on the 22mm coming out of boiler supplying hot water taps
    Other is on 15mm cold feed after the boiler inlet.
    Has anyone got any ideas?
    Do you think when i close the tap then the water tries to push back into boiler and this causes it to try and disperse it?
    any help will be greatly appreciated as im baffled
    thanks in advance
  2. Sponsored Links
  3. mickyg
    mickyg
    24 Aug 2005
    16,007
    Thanks Received:
    3,325
    Cornwall
    Country:
    dead leg. put it in search.
  4. DIYnot Local
    3 Sep 2019
    Country:
Loading...
Share This Page
