Hi, I have the above boiler and the above fault code keeps coming up and stopping the boiler from time to time. Its not a great issue but im worried that it will damage the boiler. When i re-start the boiler after the fault code, i notice the pump struggles with a series of short grinding sounds. I also noticed there is a tiny leak between the magnatec and the pump (not sure if relevant). I have bled the pump to no avail, the rads are bled too. I had the setup serviced less than a year ago, the plumber i used didnt have a diagnostics kit so he suggested to use valliant, which im loathe to do as id rather use and maybe re-use a loacal plumber. So in short have any of you guys got an idea and can you recommend a solid plumber to look at the issue.
regards
Ben
regards
Ben
