valliant boiler turbomax plus824e
1 Apr 2009
Kent
when heating on have hot water when heating off no hot water new pcb board fitted by others been ask to find out problem any help please and is it easy to replace part.
,,,,,.....?///// just a few for your post as i've got some spares
diverter valve cartridge is most likely cause. and yes if you know what your doing its an easy job
cheers mate is this expansive part to by and do i have to drain down hot water side only i have not worked on this type boiler before
check the pin on the motor is moving(remove surclip and pull it off)
most likely dirt in the bobbin-turn the hot water off at inlet and drain heating side of boiler.
a new kit isnt that costly.check for sludge and grit
advise on a new boiler or a magnaclean :D :D
woops thought i was on a job there
ignore that last post somehow i read vokera linea max
still asleep
older turbo max divertors have problems with the mechanical ball sticking in the divertor
theres a new modified divertor available $$$
