valliant ecomax
19 May 2008
London
hiya, i just bought a flat with a valliant ecomax boiler, its been great until today when its showing F25 error and wont turn up when turned off and on again. i think i may need to refill it as the pressure is right down, but it is not on...
so, how do i refill? there doesn't appear to be any pipes for me to do this, there is a big flue pipe on top and then all the copper pipes at the bottom, i cant get the front off it and don't know what to do!! as i just bought it, ove no money to call someone out!! help!!
Look under the boiler, just behind the front panel should be a silver braided hose. Thats the filling loop, it will have a black lever at each end, turn these 90deg and fill boiler to 1bar. Make sure you turn off both levers again after.
I thought those levers came off and were stored in the kitchen drawer?
Tony
Once you have filled it press the button with the flame and cross going through it.
Will need a reset; my missus sometimes forgets that part, then shouts at me!
cheers folks, i found the booklet in the end and got it sorted...its not good thinking you need a plumber out when you only have £1.40 in the bank...
