I would be grateful if anyone could shed some light on my current predicament.
I have installed a varilight master dimmer in my hall and a slave in my landing to control my landing light using a
two way circuit. The cabling consists of a 3 core and earth between the switches and a two core and earth from the
slave to the ceiling rose. I cannot get the light to work with the slave installed. The master will work however if
the slave is substituted with a standard rocker switch and the switch is "ON". The rocker switch however can only
turn the light off and will not turn it back on. Obviously I want to get both the Master and the slave working
correctly so I have control from both locations.
This is how the switches are wired:
At the MASTER switch:
Yellow to Load (or wavy)
Red to Live
Blue to Slave (or S)
At the SLAVE switch:
Yellow from MASTER switch to: Load (or wavy)
Blue from MASTER switch and Black to ceiling rose to: Live
Red from MASTER switch and Red to ceiling rose to: Master (or S)
Any help would be most welcome.
Red to Live
