Hi
My wife is selling her house. She had a builder replace a saniflo system with a gravity pipe which was connected to the public sewer. BUulding regs weren't signed off at the time and there are outstanding items which is holding up the sale. The following are the oustanding issues:
3.1 The existing channel must be checked to ensure that the run starts from this manhole otherwise the drop-pipe could disrupt the existing flow through the manhole.
3.2 The expanding foam used to infill the gaps around the 110mm diameter pipe in the wall of the existing manhole is not considered suitable material and must be replaced. NB. Any replacement infill material must be vermin-proof.
3.3 The 110mm diameter drop-pipe must be brought closer to the wall of the manhole and clipped to the wall using proprietary fixings.
3.4 The access point should be fitted with a proprietary access cap rather than a socket plug.
3.5 The outlet from the drop-pipe should be benched appropriately to assist discharge into the channel.
As you can see, it looks like the cowboy thought it would be covered and not seen - expanding foam!!!
Anyway can anyone advise on what needs doing - I am a complete novice on drainage so excuse the ignorance. I get 3.2 & 3.5, but the others I am unsure.
Many thanks
Adam
Many thanks
Adam
