Hi.
Just in the process of fitting a few Oak Veneer doors from Premdor. (4 panel Somerset Oak). I was going to use Ronseal Diamond Hard Clear varnish but asked Premdor if I should be using water based varnish on this product and they have just replied with "it must be high joinery grade, solvent Based Polyurethane varnish/lacquer"
Any suggestions as to what I should be using and is there really a valid reason for not using water based.
Whatever I use, I want to be as clear as possible to retain the appearance of the timber.
Many thanks,
Andy.
Many thanks,
Andy.
