vauxhall combo van alternator
12 Jan 2010
1.7dti 2003 plate
Ok been having trouble with this van from the start
now it seem the alternator might be going.
had a look on youtube about testing them and these are the reading i got
12.48v(dc) just battery enginie not running
11.67v(dc) engine running
11.54v(dc) engine running with lights on
11.43v(dc) engine running with lights wipers and indercaters on
somtimes the van starts then does'nt but starts first time with a flash over
yesterday i took the battery off and swapped it off another van my van started but the battery light stayed on on the dash board.
i also unbolted the harness from the battery to the framework on the van and cleaned the end.
its in the front left drivers side of the van
thanks
Lee
Goosed alternator mate.....with the engine running reasonably quick, you need to see around 14.4v with lights etc on.
Eventually the battery will be so discharged, it won't run the vehicle at all.
John :)
thanks burnerman
its weird cause i did the same test the other day and i was getting around 14.10
then lights on 13.26
are these easy to change (DIY)
ive been quoted 250 inc parts over the phone (i no this is not a price quoting site) but wondered if this is reasonable
ive changed one before myself before seem to remember just a few bolts and release the belt but this one does look different due to have two tube connect to it.
if i do decide to have a pop at it can you recomened a haynes book as i cant seem to find one
thanks
Lee
Lee, there's always a possibility that you have an electrical connection problem...basically the thick wire on the alternator connects directly to the battery, and the thin one takes whats known as the battery exciter voltage in - feel free to see if they wiggle, but watch the drive belt!
I still suspect the alternator though.
The two rubber pipes are for the brake servo evacuator pump.
I can't comment on how easy it is to change the alternator, but if I recall an earlier post access is tight.
To give you some idea, get a couple of motor factor price quotes for the alternator exchange, and you'll see approximately what the labour charge is.
John :)
thanks for the help guys
thats a very good point on the harness burnerman
also thanks pete for the link
ill let you no if i brave it or not
Lee
Vaux test spec off TIS2000 is 13.7v to 14.v at idle then the same with everything on at 2000rpm, Measuring voltage at B+ on Alternator with a clamp meter.
Long one
J705100 Alternator, Remove and Install or Replace (Y 17 DT, with AC, LHD)
1. Open bonnet
2. Evacuate air conditioning
Note! Drain air conditioning – see operation "Air Conditioning, Drain " in group "D"
Caution!
On vehicles from model year 04 with ESP - the steering angle sensor loses its basic adjustment each time the battery is disconnected. It must be recalibrated.
3. Disconnect battery
Detach ground cable
4. Remove air cleaner housing (1)
Disconnect wiring harness plug for hot film mass air flow meter (3)
Release in direction of arrow
Remove air intake hose (4)
Loosen clamp (5)
Remove bolt (2)
5. Unclip brake servo vacuum line
5 brackets
Set to one side
6. Remove charge air hose (2)
Release 2 clamps
7. Detach centre charge air pipe
Remove upper bolt (1)
8. Release upper front panelling
Remove 3 bolts (1)
9. Raise vehicle
10. Release lower front panelling
Remove 3 clips (2)
Remove 4 bolts (1)
Remove 2 nuts (3)
11. Detach front panelling
Note! 2. mechanic
Remove and close the hose – high-pressure – Headlamp washer system
With KM-807
12. Raise vehicle
13. Detach ribbed V-belt cover
Remove 3 bolts (1)
Remove clip (arrow).
14. Detach ribbed V-belt
Tension ribbed V-belt tensioner in direction of arrow
Using KM-913-A at fastening bolt (1)
Note! Mark running direction
15. Detach centre charge air pipe
Remove lower bolt (1)
Loosen clamp (2)
16. Remove lower charge air pipe
To charge air cooler
Release clamp
Remove lower charge air pipe from guide
17. Detach vacuum hose for vacuum pump (3)
18. Detach alternator wiring harness
Disconnect wiring harness plug (1)
Unscrew nut (2)
19. Remove vacuum pump oil feed line
Place collecting basin underneath.
Unscrew banjo bolt (4)
20. Detach vacuum pump oil return hose
21. Remove AC line (2)
Unclip wiring harness
Disconnect pressure switch wiring harness plug (1)
Remove bolt (3)
Set line to one side
22. Remove alternator
Remove 2 bolts (1)
Remove brake servo vacuum line
Unscrew nut
23. Detach vacuum pump (1)
Remove 3 bolts
They are LOL
One of them is on my scariest drives Visa Gt with the BX Gti lump in
Most of that can be left out ( that what vaux "may" follow in theory)
The ford description is ever worse aimed really low on the skill set level
just throught id let you no it was the alternator.
steering went really stiff ect
i was going to have ago myself but after reading stuarts post i felt like cracking a berr open instead
cheers for the help
Lee
steering goes stiff as the ecu in the steering stops the motor drawing power when voltage drops to lol, The joys of electric based steering
well the van diddnt start this morning untill i flashed it .
got to the job was in there for hr and it had to be flashed again.
after that seem ok for the rest of the day but kept the engine running a lot.
any ideas
can a alternator kill a battery?
thanks
