    Dismiss Notice
Vauxhall Movano help
Discussion in 'Car Repairs / Maintenance' started by buck73, 11 Jun 2013.
  1. buck73
    buck73
    11 Jun 2013
    2
    Thanks Received:
    London
    Country:
    "Got a vauxhall movano van 2003 filled up with oil and on the motorway the engine and cabin was filled with smoke, the revs were at 5000 revs and when took the key out the engine was still running, what did i do wrong"
  2. Burnerman
    Burnerman
    7 Feb 2008
    20,141
    Thanks Received:
    3,910
    Northumberland
    Country:
    Errr who knows but I don't think the turbocharger is very well at the moment......did you overfill the oil level? It sounds like the engine is running on its own lubricating oil.
    John :)
  3. Sponsored Links
  4. buck73
    buck73
    11 Jun 2013
    2
    Thanks Received:
    London
    Country:
    I think i did overfill the oil
  5. Burnerman
    Burnerman
    7 Feb 2008
    20,141
    Thanks Received:
    3,910
    Northumberland
    Country:
    Diesel engines can consume their own engine oil.....if a turbo oil seal fails then oil is ingested and the engine speeds up until eventual destruction.
    The same can apply if the level is very high - oil vapour and liquid is expelled through the breather pipes and into the air intake with the same consequences, often enough.
    If you are quick the engine can be stalled......whats the state with yours now?
    John :)
  6. Sponsored Links
Loading...
Share This Page
