Vent types for venting extractor through roof
23 Jun 2012
Nottingham
Looking to vent 2 extractor fans through pitched roof.
I know you can get the tile vent type as well as the cowl.
Which one is better?
We prefer 100mm pipe via a multi-slate with mushroom cowl. More flexible positioning.It means we can locate the pipe between two tiles, allowing us to cut a bit out of each tile.
You just need to be careful dressing the lead and avoiding rafters.
Is the pipe rigid or flexi? If flexi doesn't it get condensation build up
I have vented mine through the attic into the soffit. Originally I bought one of these cheap fans from screwfix that sits directly above shower with a light, but the fan conked out after a couple of years so I bought a manrose MF100T to give it a bit more extraction power. I sat this new unit on a piece of scrap ply which sat on a couple of joists in the loft, to minimise the vibration I add added some foam under the ply where it sat across the joists which I then lightly secured with screws.
Yes rigid pipe.
That depends how you choose to weather the hole through the roof surface. 110mm plastic pipe is the most convenient.
Don't some tile vents come with a flexi hose attached? The extractor pipes are 100mm guessing you need an adaptor for the 110mm?
