D
Deleted member 245507
Good Morning,
I am in the early stages of planning the central heating system to install in a stone cottage. The property is currently served by a truburn solid fuel range with a back boiler capiable of 90 000 BTU (26kw)in 24h feeding a 117l tank. Aside from this there is no other heating source. In my mind I feel that it would be best to have underfloor heating downstairs and a raidiator in each room upstairs (3) plus a towel radiator.
I was wondering how I would go about connecting the range, solar and under floor heating. I was thinking that the truburn would feed in to the indirect hot water cylinder as the indirect heat source for the top coil with the out flowing to the radiators upstairs, and the solar as the indirect heat source at the base (I think you can find tanks which have two coils?). But I'm stumped as to how the underfloor heating would be connected to the system, I'm assuming the out from the solar would be too cold to feed the under floor heating. Equally I thought that feeding the underfloor heating from the radiators before it returns to the back boiler would be too hot? The Truburn would not be on during some of the Summer months and so I was also interested to know if a immersion heater and a solar panel would be enough for a 117L tank?
I am probably way off with how this all works so any advice or points in the right direction would be appreciated. I have looked around the forum, but can't find anything similar to this (which probably means I'm completely wrong in how it would be set up).
Many thanks,
Ed
Many thanks,
Ed
