Not mentioned in Lochinvar literature.
Not mentioned in Vaillant literature
6 pages of pish.
6 pages of pish.
A pressure regulating valve did fail to control pressure and the results of that failure were the reason for the discussion starting on the other forum.
I would like to point out that the context was NOT an RGI working to his or her training but a house owner concerned that gas might be leaking in small quantities from a recently removed bayonent coupling A bubble test would give peace of mind or alert to the need to get the pipe selaed properly.I should like to point out that you recently advocated using fairy liquid to find gas leaks.
For some people Housing associations and co-ownership schemes are the only way to get a decent place to live. And not all schemes are poor quality. One such scheme isHousing associations![]()
So a housing association can't guarantee to install and maintain the system properly, therefore you conclude it is an inferior system.
No one has said the un-vented system is inferior
