venting into loft
28 Feb 2007
Kent
hello everyone i was hoping for some advice.
i am looking to get a portable air con unit for a small upstairs bedroom which comes with an exhaust hose.
I realize its probably not ideal but is it ok for me to cut a hole into the loft for this to vent the air into the loft?
If the unit i get says it has a water tank that needs emptying i presume this means all that comes out of the hose is warm air so moisture going into the loft shouldnt be a problem?
This would be so much better for me than out of the window or through the wall.
thanks all
I could do that yes is it OK tho if the exhaust tube is a bit longer then? It doesn't effect how well it works?
Thank you ALC I appreciate your advice
Venting into you loft isn't ideal but it shouldn't hurt your timber... the air coming from a monoblock unit will be warm but dry as the air is drawn from the room to cool the condenser... If you have a well ventilated loft then there should be little problem but if ventilation is poor then the loft will just get hotter and hotter..
Have you considered having a decent quality Minisplit fitted.. Quiet, efficient and will last a lot longer than a disposible monoblock
And they will heat too.
i would check with the manufacturer as there will be a maximum distance horizontally and a reduced distance vertically it will operate efficiently
I think the loft is quite well ventilated so it should be OK then which would be great if I can do that. I did look at the split ones but I was just trying to keep the cost down as it is a bit out of my price range to get one of them fitted.
And I will check the manual for that distance to see if there is a way to get it to vent outside the loft.
Thanks guys for trying to help me and not just be childish like some.
