Hope you chaps are getting on fine now!
Im going to spend a bit of time over the weekend trying to get the Trevi to work.
A couple of potential issues might be;
I have 22mm check valves on hot and cold. I bought these asking for 22mm check valves, what if I have installed double check valves instead of single. Small brass screw mid body of valve, small white plastic ball at one end, plastic grille at other. Does that sound like a double or single valve?
Would a double give the symptoms referred to?
Also connection from mixer to handset 15mm flexible. tightish radius off copper fitting to reach handset.
JA
JA
