Veritas 8 - Instant Arm?
3 Sep 2008
Tyne and Wear
Hi all,
Installed a Veritas 8 last month with some invaluable help from this forum, however I'm wondering if there's a way to instantly arm it when we are in the house and going to bed. Instead, we have to sit through 30 seconds of quite loud beeps late at night.
Thanks in advance for any suggestions,
BS...
They should be quiet blips for part set. Assuming you have programmed a full and part set?
Exit time from keypad to unprotected part set can be adjusted to how ever many seconds you want.
Assume you have manual if you installed this?
Have only programmed full set. Is the answer to program a part set for the same zones but reduce the set timer as low as possible?
Cheers,
Carl...
