Veritas Alarm not setting
18 Oct 2006
Buckinghamshire
We have a Veritas 8 (maybe 8+) installed around 12 years ago (before we bought the house).
A couple of weeks ago it would not set - Wife could not get the keypad to do anything. When I got in lifted the cover on the keypad (sounders went off) and eventually by pressing reset it started working again. Since then it has done it a couple more times and pressing the rest and the code a couple of times gets it going again.
Last night it would not set - it beeps when the keys on the left of the panel are pressed.
I have had one sensor off to decorate but that was after the first incident.
Doesn't normally behave like this when it needs a battery.
Any suggestions to fix it.
Ever replaced the panel battery, you should be on your 3rd at least by now, should be replaced every 5yrs max.
A battery can cause a multitude of strange and random faults when this old, 12yrs?
You need a new battery, Yuasa NP7-12 12V, 7Ah, Screwfix is a good place to go, they will know what you are talking about.
Don't go to Maplin unless you have money to burn.
It's always good practice to replace the rechargeable battery in the panel every 3-4 years, it may or may not cure your problem but a faulty battery can cause a wide range of symptoms.
Either way, if it hasn't been changed for some time, it won't do any harm and you know that your system has a healthy power supply.
Could be one of the keys on the keypad sticking or the membrane under the keys that's knackered,the veritas keypads are not normally troublesome ...
New battery fitted last night, CEF don't carry Yuasa anymore but got it for just under £20. The one fitted is showing very slight bulging to some of the cells and has been in 4-5 years, didn't write the installation date on it last time but wife says it is before she started her current job.
Managed to get the panel to respond when I got in by entering the code several times , changed the battery and wiped the switches behind the keypad.
Seems to be working now but only time will tell, it has gone days between sessions of not responding over the last week or so. If it does it again I will change the keypad.
you can get kits to replace the buttons and the membrane DCA-0015 under £7 on ebay.
sounds more like keypad issue to me from what you describe.
I had an issue on one of these in my uncles house 1 row of keys wasn't working, I took the ribbon out of the keypad blew in it and put it back in, this was two years ago and it's been right as rain since. Which reminds me it's time to change his battery
