Veritas R8+ alarm prob.
16 May 2013
Nottinghamshire
Have just fitted a Veritas R8+ alarm with 2 remote keypads (4) wires none doubled up, everything works OK but I cannot alter time delay on entry (set at 35 secs) and the beeps from keypad are almost inaudible.
(1) To alter time delay manual states on page (30), engineer code (1234) then press prog then press (3) then (3) for (full set entry time) then time in secs, in my case 60 then press prog, nothing happens, the delay remains at (35 secs). What am I doing wrong?.
(2) How do I increase the volume of the beep from keypad.
Thanks,
Rob.
Reset twice, 1234 prog (all lights illuminated?)
enter the code to change the timer (33), 60 two numbers illuminated on keypad press prog, should get acceptance tone.
did any part of that not happen?
I will try that Monday (reset twice) thanks, the alarm is in another house, I have same alarm but older model, just changed time on mine from 20 secs to 60 secs, worked OK.
Can I increase sound from keypad.
Thanks,
Rob.
all the reset twice does is make sure you are not in any menus.
I suspect you didn't get into engineering but depending on how the panel responds will indicate that.
only place to increase volume is in the main panel unfortunately.
The keypad tone is low on second keypad, this keypad is some distance from control panel, will doubling up the 12 volt and 0 volt rails improve this.
checking the voltage at the keypad would be a start ! Doubling up the power can't hurt !
