Very confused about metpost/stakes - question
18 Aug 2008
Devon
Hi all,
I have some 50mm metposts I would like to put 50mm wood into and make a fence to act as a windbreak for my veg patch. The frustrating thing is that I can't seem to find 50mm finished wood. I don't mind if it's bare pine or whatever, I'll paint it, but I can only find 50mm wood which is actually 44mm finished, meaning I have to make a wedge for each post/stake to make it sturdy. Is there something obvious I'm missing here?
Fair enough. I guess the 3mm allows for expansion of the wood in wet weather. I just hope that what I'm looking for is actually suitable for the application.. if that makes sense
what type of metpost - some have a bolt at the top to pull the square into the post , others just use a flange inside which holds the post - I prefer the bolts version when i use them , only used with 3x3" 75mm and 4x4" 100mm posts thought not 2" 50mm
wrong size - but this idea on bolts
https://www.toolstation.com/drive-i...cUvlSNkgVq8yVFRcCPRQom9qFLynr-X4aAreaEALw_wcB
and flanges - this is what I meant, again wrong size just an idea
https://www.toolstation.com/easygrip-post-spike/p56458
I have also used slithers of wood to pack out and the posts are still up
The bolt ones are ideal but I didn't get those ones. I picked up a load of them cheap and just felt the price was right. I realise it's not ideal. Thanks for your recommendation on the wood. I hope there isn't the opposite problem and the 50mm finished size is too big to fit into the metpost haha
https://www.travisperkins.co.uk/tre...YJ9AqaWUFvULMAiCjDQaAhQMEALw_wcB&gclsrc=aw.ds
the sawn is normally not finished/planned and actual size , usually planned is then a finished size
worth a call
also a measure the inside size of the metpost
As you are showing London, there will be a few timber yards, probably the chains like travisperkins as linked champions maybe -
I saw a good timber yard in west london by Peter Millard on youtube on friday - not sure if that is near to you or if they stock fencing posts
I use alsford timber a lot https://www.alsfordtimber.com/
I bought rough sawn, marked the end that was going in the post and then planed/sanded the top section. My size was 150 x 150 x 2000
It had the corner bolts which bit into the rough end and then I drill all 4 sides and secured with coach bolts.
If you are using 50 x 50 you could, as suggested, use packers to equalise it centrally and then bolt it in position from all four sides. It's a good idea to stagger the bolt heights slightly so opposite ones don't hit each other.
