Any electronics experts out there.
I purchased a friedland chime 6 months ago pretty expensive should work up to 200 metres. Unfortunately it is totally unreliable. Sometimes it just does not work at all. However if I take off the bell push remove the battery and leave it a bit then put the battery back in it invariable will work. I then put the bell push back on and by the next day it has stopped working again.
Definetely not the Battery as I have changed twice and multimeter reads about 3.2 volts (3v battery). The chime plugs into the mains so not problem there. The chimne is only 10' from the push and doors are made of wood.
Can I test this anyway. Has anyone had a similar problem. Any help greatfully received as I am now lost.
