Very noisy fridge: Noise stops immediately when door opened.
7 Jan 2014
West Glamorgan
As the title... I have a Leibherr 2 piece fridge freezer and the fridge side has started being very loud (a buzzing). It stops immediately we open the door, which seems odd.
Any ideas? Thanks
It's the internal air circulation fan, either jammed by ice, or maybe faulty. Try thoroughly defrosting it.
it could be side or back contact on surfaces causing vibration and when you open the door it moves the weight distribution stopping the points off contact have you tried wiggling pushing/pulling /squigling the carcase to reduce surface vibration even fingers in-between edges to work out where the noise is??
That is what I was thinking which is why I asked what happens if you actuate the door switch while it's open.
There is no obvious door contact on my new upright freezer, but it obviously detects the door being opened, because if the door is opened when the air circulation fan is running - the fan is stopped.
Tried all that, to no avail. Not buzzing right now, as it happens.
My neighbour had a freezer bag that had pushed a corner through the vent to catch the fan blades
