I live in a Victorian terrace. My front door has been covered up with sheets of fibreboard on both sides for as long as I've lived here. Years ago a decorator had a look under the fibreboard and said he thought it was the original front door.
I've recently removed the fibreboard on the inside. Underneath, the two top panels of the old door were completely missing. They'd obviously been glass at one point. The glass didn't look original - it looked like the panels had either been reglazed, or glass had been used to replace solid panels.
I've hung a temporary front door and moved the old door inside to have a better look at it and hopefully restore it.
Removing the fibreboard from the front (the outside), it's even more knackered than I thought. It's got the remains of cricket bat panels in the lower half. But parts of the panels - the wood surrounding the cricket bat centres - are missing. There's nothing left of the upper panels at all.
I've removed the weather bar for now and pulled out all the tacks and nails. My plan was to strip the paint, put new flat panels in the top half and possibly remove the lower cricket bat panels, leaving them flat. Then I thought I'd fill all the holes and add bolection mouldings around the panels. But maybe I'm kidding myself - it is in a much worse state than I'd expected and I'm definitely not an expert carpenter. Plus the paint probably has lead in it so perhaps I should leave it alone.
Anybody got any tips or suggestions?
