Hi
I am due to replace a 2.5kw electric underfloor heating system within a suspended timber floor in a conservatory. The conservatory is circa 9 years old with Argon filled double glazed units on two walls and the roof.
Can the Viessmann 200w with weather compenstion be configured to take an additional circuit/zone for a single room underfloor heating system such as a Polypipe single zone unit with room stat, can this be wired back to the boiler even with the weather compensation unit fitted ?
If the Polypipe system is not the right one which is ?
As the conservatory manufacturers had suggested a 2.5kw elect system I imagine that this may have been based upon a heat loss calc, but the underfloor wet system will only produce a fraction of this at circa 70w/m for a in joist system with double spreader plates. I already have a small radiator within the conservatory, which can be isolated can I also link this into the propossed underfloor heating circuit so they can be controlled by one room stat ?
I am lifting the floor as it is a suspended timber floor with 25mm of polystyrene in and is freezing in the winter unless you run the £10 per day electric system. My first step is to install 100mm celotex and then use a wet system with speader plates with plywood and then tiles over the top. Does this sound right ?
any guidance would be very useful or if there is a better way to heat the room with my boiler and weather comp set up I would be very happy to hear about it.
