vinyl floor in bathroom
4 Aug 2019
Hi, I fitted a 4mm vinyl floor in out bathroom about 3 years ago, I'm wonder, is there anything i can apply on it to give it a wee bit of life, its a bit dull looking.
I know it can't be a slippy surface, just something to make it look, not as dull :)
Thanks in advance.
Is it a a Sheet Vinyl or a Luxury Vinyl Tile product?
What have you been cleaning it with?
Hi, I have vinyl flooring planks about 150mm wide and about 1400 long, (T&G)
I just used warm, a little soapy water to wash the floor. The floor isn't dirty, just was looking something to put a wee bit of a shine on it.
Thanks.
Sounds like you have a LVT floor, you have a couple of options, you can try using a LVT floor cleaner or you can use LVT renovation products, have a look at the Dr Schultz range, it maybe a build up of detergent not fully cleaned off the surface rather that a surface issue itself.
OK ,Thank you for your advice, will do.
