Visonic Powermax Alarm enrolment problem
7 Oct 2021
Hello, I can't enrol new keyfobs. I enter my password which I chose after installation - but then the menu prevents me from accessing the enrolment menu. This is the only password I know but it says that only the Master password will allow be access? I'm really confused.
20 Jun 2014
Lancashire
Sounds like you don't have the master password, the default one should be in the manual.
If you haven't set this up yourself then you should look getting the manager/master code changed asap.
7 Oct 2021
Thanks - there is a default password in the manual but that doesn't seem to work. I'm in a new development of several houses where the alarm was pre-installed and then the installers just disappeared. I'm trying to contact the building company to see who installed it. By the way don't Visonic have a helpline office in the UK?
20 Jun 2014
Lancashire
They do (or at least did relatively recently for installers only) and the default procedure for codes only are in the installer/ engineers manual if I recall correctly.
