Hi guys, here's hoping you can help me out with this one...
I have a combi boiler as above. Not been serviced in years (previous owner!).
I've been having to fill the system with water every few weeks because of falling pressures. Then my boiler started making funny noises. The noise is a creaking sound, like something needs to be oiled. It only occurs when the central heating is on (whether or not the boiler is fully fired) and when a hot water tap is turned on it stops for the period that the tap is on.
I got my boiler serviced. The major issue noticed was that the diaphragm had gone and the heat exchanger cracked. The diaphragm was changed and I've been quoted to get the heat exchanger and all appropriate other items replaced (£350). The plumber wondered if the noise might have been caused by trapped air in the system
Initially after the service the noise went. However the noise has started again, though it's not as bad as it was before the service.
I have 2 questions for the forum:
1) What do you think is causing the noise?
2) Given the age of the boiler (over 12 years old or so) is it worth repairing the heat exchanger or should I get a whole new boiler (£3000 including changing the piping from the gas meter)?
All comments gratefully received!
