    Dismiss Notice
Vokera Linea 24, not getting up to Temp on Heating or water
Discussion in 'Plumbing and Central Heating' started by Dan scotland, 11 Aug 2007.
  1. Dan scotland
    Dan scotland
    7 Apr 2005
    17
    Thanks Received:
    Country:
    Problem as above when the hot tap is on the boiler fires up but quickly shuts off, so the water is slightly warmed then flows cold the boiler continually cycles on and off, with out getting to a constant high temperature, this happens on the hot water and central heating....
    The diagphram has been changed, yes the old one had pin hole in it, but the boiler still does not get to Temperature...
    Any suggestions as to the cause :?:
  2. Sponsored Links
  3. clf-gas
    clf-gas
    2 Mar 2007
    3,441
    Thanks Received:
    64
    Lancashire
    Country:
    Renew the thermistors
  4. DP
    DP
    10 Dec 2003
    14,636
    Thanks Received:
    3,202
    Glasgow
    Country:
    What diaphragm did you change?
    Boiler has two thermistors. Unlikely bothe are defective ( note boiler malfunction for CH AND HW).
    Get boiler serviced. Do not come back and say boiler has been serviced if service took 15 minutes or so !!!
  5. nickso
    nickso
    30 Oct 2006
    6,721
    Thanks Received:
    301
    Country:
    if it cycles on and off rapidly on both ch+hw then its most likely the ignition pcb at fault.
  6. scatmanjohn
    scatmanjohn
    2 Nov 2005
    3,391
    Thanks Received:
    237
    Country:
    I second that ;)
  7. Agile
    Agile
    26 Jun 2004
    63,985
    Thanks Received:
    4,583
    London
    Country:
    Please quote the seconds on and seconds off to enable us to better diagnose the possible cause.
    Could also be a slow or blocked pump.
    Tony
  8. Dan scotland
    Dan scotland
    7 Apr 2005
    17
    Thanks Received:
    Country:
    With the Hot water on the boiler switches on for about three seconds then off for about four seconds, and repeats approx cycle, the initial on phase may be a little longer, but not much!
    Hope this helps the Diagnoses
  9. Sponsored Links
  10. Agile
    Agile
    26 Jun 2004
    63,985
    Thanks Received:
    4,583
    London
    Country:
    The ignition is common to the heating and the hot water.
    Such a short cycle time is typical of an ignition fault.
    However, most ignition faults would cause the boiler to lock out, but not all!
    I would therefore first be checking the fan/venturi/APS as thats free to clean or cheap to renew the APS.
    Afterwards, if that did not identify the cause I would be suspecting a lack of flame detection. That would be electrode, lead or PCB.
    Tony
  11. nickso
    nickso
    30 Oct 2006
    6,721
    Thanks Received:
    301
    Country:
    if does that on ch as well then its almost certain to be the ign pcb
  12. Dan scotland
    Dan scotland
    7 Apr 2005
    17
    Thanks Received:
    Country:
    Fan seems fine, Ok got it Air pressure switch... all seems OK time to get profesional ...
    any service engineers that can be recommended in the Hamilton Area?
  13. DP
    DP
    10 Dec 2003
    14,636
    Thanks Received:
    3,202
    Glasgow
    Country:
    Water in Glasgow has pH 0f 7. Cannot imagine Hamilton water quality will be all that different.
    I suspect lack of modulation is only present during HW mode.
    I am based in Bearsden and can easily carry out service/ repairs in Hamilton.
  14. Dan scotland
    Dan scotland
    7 Apr 2005
    17
    Thanks Received:
    Country:
    Sounds good to me do you have mobile no or works no?
    one boiler engineer has been suggested, been contacted but no response yet, so will give 24 hrs to contact..
  15. DP
    DP
    10 Dec 2003
    14,636
    Thanks Received:
    3,202
    Glasgow
    Country:
    See my profile in this section
  16. DIYnot Local
    3 Sep 2019
    Country:
Loading...
Share This Page
